Dobrodošli, Gost. Molim vas prijavite se ili se registrujte.
Prijavite se sa korisničkim imenom, lozinkom i dužinom sesije
Linuxo Forumi
Stranice: 1 [2] 3   Idi dole
  Štampaj
Autor Tema: FC6 zavrzlame  (Pročitano 14555 puta)
0 članova i 1 posetilac pregledaju ovu temu.
BrokeBody
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 2231
« Odgovor #15 poslato: 03 Децембар 2006, 19:27:51 »
Sta je bre ovo?!?
Kod:
yum list kernel
Loading "installonlyn" plugin
Setting up repositories
Reading repository metadata in from local files
Installed Packages
kernel.i586                              2.6.18-1.2798.fc6      installed
kernel.i586                              2.6.18-1.2849.fc6      installed
Available Packages
kernel.i686                              2.6.18-1.2849.fc6      updates
I uzeo ja da instaliram kernel.i686
Kod:
yum install kernel.i686
Setting up Install Process
Parsing package install arguments
Resolving Dependencies
--> Populating transaction set with selected packages. Please wait.
---> Downloading header for kernel to pack into transaction set.
kernel-2.6.18-1.2798.fc6. 100% |=========================| 206 kB    00:05
---> Package kernel.i686 0:2.6.18-1.2798.fc6 set to be installed
--> Running transaction check
---> Package kernel.i586 0:2.6.18-1.2798.fc6 set to be erased
Dependencies Resolved
 Package                 Arch       Version          Repository        Size
Installing:
 kernel                  i686       2.6.18-1.2798.fc6  core               16 M
Removing:
 kernel                  i586       2.6.18-1.2798.fc6  installed          43 M
Transaction Summary
Install      1 Package(s)
Update       0 Package(s)
Remove       1 Package(s)
Total download size: 16 M
Is this ok [y/N]: y
Downloading Packages:
(1/1): kernel-2.6.18-1.27 100% |=========================|  16 MB    05:45
Running Transaction Test
Finished Transaction Test
Transaction Check Error:   package kernel-2.6.18-1.2849.fc6 (which is newer than kernel-2.6.18-1.2798.fc6) is already installed
  package kernel-2.6.18-1.2798.fc6 is already installed
[root@stefan stefan]# rpm -Uvh --force kernel-2.6.18-1.2798.fc6.i686.rpm
error: open of kernel-2.6.18-1.2798.fc6.i686.rpm failed: No such file or directory
Posto nece ovako, gde se moze rucno preuzeti i686 paket?
« Poslednja izmena: 26 Децембар 2006, 08:52:16 od tomaja » Prijavi uredniku   Sačuvana
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #16 poslato: 03 Децембар 2006, 21:38:36 »
To ti je sveza instalacija zar ne?
Kao sto je pomenuto gore,usled bug-a u Anacondi ona umesto i686 kernela instalira i585 kada je u pitanju FC 6,sto stvara problem prilkom update-a :Smiley
Potrebno je da na dvd-u nadjes kernel koji se zove ovako kernel-2.6.18-1.2798.fc6.i686.rpm
Ovo i686 je kljucno u nazivu
Zatim ga prebacis na hard i instaliras sa rpm -Uvh --force kernel-2.6.18-1.2798.fc6.i686.rpm
Posle toga mo's da nadogradjujes sa neta kako hoces....
PoZ!
P.S Kernel paket se nalazi u core sekciji na bilo kom mirror-u Wink
Power of simplicity - http://www.archlinux.org/
Blog - http://ratos81.blogspot.com/
Besplatni knjizevni magazin Eniaroyah - http://www.eniaroyah.info/
kmilos
Hero Member
Van mreže Van mreže
Poruke: 1449
« Odgovor #17 poslato: 04 Децембар 2006, 00:26:39 »
@BrokeBody
Piše već lepo na ovoj temi da ne može i686 da se zameni kroz yum, a link ka "common problems" daje detaljno objašnjenje kako izvesti operaciju...
Inače, kad već ovo radiš, stavi odmah ažurirani kernel-2.6.18-1.2849.fc6.i686, a možda yum sa celom ovom kobasicom čak i prođe...
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #18 poslato: 09 Децембар 2006, 01:10:24 »
Korisni linkovi za pocetnike:
http://www.fedorafaq.org/
http://www.mjmwired.net/resources/mjm-fedora-fc6.html
http://easylinux.info/wiki/Fedora_frog
http://fedora.redhat.com/docs/
http://fedoraproject.org/wiki/
http://fedoranews.org/cms/
Dovoljno,nadam se i neka admini konacno stave ovu temu kao sticky
« Poslednja izmena: 26 Децембар 2006, 00:47:46 od Seleuk » Prijavi uredniku   Sačuvana
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #19 poslato: 13 Децембар 2006, 16:19:41 »
Svakako vam nece ruke otpasti ako ovu temu stavite kao sticky :Smiley
Ljudi su se potrudili i dali dosta korisnih saveta koji mogu da pomognu novim Fedora korisnicima i pocetnicima Wink
STAVITE OVAJ TOPIC KAO STICKY!  Cheesy
GoranSTX
The inevitable...
Global Moderator
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1232
Autoportret autostopera
« Odgovor #20 poslato: 13 Децембар 2006, 21:10:07 »
Eto i ja instalirah FC6, cisto probe radi pa nabasah na problem(e):
1. Koristim KDE, instalirao sam nVidia 1.0-9631 drajvere i compiz i u GNOME-u mi daje opciju "Enable special effect-s" ali ne moze da ih pokrene. Na KDE-u ne mogu ni da nadjem takvu opciju. Predlog? Hteo bih i ja malo da okrecem kockicu i lepim prozore!
2. Wireless PCI MSI CB54G2 kartica nije prepoznata, krecem sad u lov na drajvere, ali ako neko ima neki savet nek se javi...
3. Sta sam to uradio kad stalno moram da lupam CTRL-ALT-F7 da bi dobio Login Screen i kako da to popravim?
4. Napravio sam lokalni repo po uputstvu mog sugradjanina (hvala), medjutim, kako da dodam pakete koje skinem sa neta rucno u taj repo? Probao sam da napravim repo ponovo sa createrepo ali yumex ih ne vidi...?
Pozdrav i hvala unapred!
« Poslednja izmena: 13 Децембар 2006, 21:35:03 od GoranSTX » Prijavi uredniku   Sačuvana
http://autostoper.blogspot.com
Two things are infinite: the universe and human stupidity; and I'm not sure about the universe. (Einstein)
Registered Linux User #411782
http://counter.li.org/
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #21 poslato: 13 Децембар 2006, 22:02:17 »
Pozdrav!
1. AIGLX ne moze da radi(za sad),ako se ne varam sa proprietary Nvidia/ATI drajverima,vec samo sa DRI-em u okviru samog Xorg-a,sto u prevodu znaci mozes da se(za sad)oprostis od AIGLX-a jer Nvidia kartice(bar novije) nemaju vec pomenutu DRI podrsku u X-u,vec se moraju instalirati vlasnicki drajveri(opet neka me neko ispravi ako gresim Wink)
Za XGL je obrnuta situacija-nece na DRI-u,a 'oce na proprieatry drajverima :Smiley
Istina je da AIGLX lepo izgleda,ali posle nekog vremena pocinje samo da smeta u produktivnom koriscenju dekstopa a i usporava mi aplikacije(pretpostavljam da je to zbog sporosti samih DRI drajvera(koristim Radeon 9600Pro)u odnosu na vlasnicke),a i compiz mi se zabrlja cim se izlogujem iz Gnome-a,iako do tog momenta sve radi dobro,sto mi govori da cu morati ipak da cekam update,mada je u pitanju softver u teskom testingu pa su moguce jos mnoge gluposti :Smiley
2. Hmmm-mozda da pokusas sa ndis wrapper-om-za wirelles nisam toliko merodavan,ali cisto sumnjam da je taj MSI podrzan u samom kernelu-ovde ce morati da ti pomogne neko drugi Wink
3.Nisam siguran,ali cini mi se da ti se loguje u jednu o tty serial konzola-pokusaj da pogledas u podesavanjima za gdm(login manager)
4.Mozda najjednostavnije bi bilo,da kad skines te pakete,napravis novi repo samo od njih(dosta brze u svakom slucaju nego da ih dodajes sa paketima sa dvd-a pa da opet pravis repo od svih)-trebalo bi da radi,jbg jeste zongliranje kada se ima los net...
kmilos
Hero Member
Van mreže Van mreže
Poruke: 1449
« Odgovor #22 poslato: 14 Децембар 2006, 01:29:31 »
1. Upravo tako kao što je Seleuk opisao. Pravi se inače DRI drajver za nvidia kartice, ali ide sporo: http://nouveau.freedesktop.org/wiki/
2. Pre ndiswrapper-a vredi pokušati naći Linux native drajvere. Udari "lspci -v" da bi identifikovao čipset pa da vidimo dalje.
3. Možda si instalirao kao server? Ako nema te opcije u System->Admin->Services (ne sećam se), onda proveri ručno /etc/inittab, kao i da ti se možda nije provukla neka 3 ili 4 na kernel liniji /boot/grub/menu.lst... (A za ovo si stvarno mogao da ne budeš lenj i pretražiš malo forum)
4. Jeste bolje da se naparvi zaseban lokalni repo za pakete sa strane. Ako ih yumex ne pokupi odmah, šta kaže yum u terminalu? Probaj možda i sa namernim brisanjem keša: "yum clean all"
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #23 poslato: 26 Децембар 2006, 01:06:37 »
Evo jos par hintova Wink
Vec sam spomenuo kako da napravite lokalni repo-da biste isti stavili u funkciju potrebno je obrisati kompletan yum cache sa "yum clean all"(ili clean cache preko Yumex-a) i iskljuciti sve druge repoe sem lokalnog i core repoa(najbolje je staviti zeljene pakete zajedno sa core paketima sa dvd-a pa od toga napraviti lokalni repo,uglavnom zbog toga da bi se zadovoljile sve zavisnosti)
Kada zavrsite dodavanje zeljenih paketa iz lokalnog repoa,mozete ukljuciti ostale i osveziti cache preko neta(automatski se izvrsava kada hocete nesto da instalirate preko yum-a online,a sam proces preko dial-up traje nekih 15min)
Sledeca stvar je problem sa instalacijom i585 kernela umesto i686-tice(bug u Anacondi)
Medjutim,ako radite svezu instalaciju potrebno je dvd podici sa komandom "linux i686" i sve ce se instalirati kako i treba Wink
Takodje,ako opet radite svezu instalaciju ne treba u Disk Druid-u stavljati mount pointe za reiserfs particije(ako ih ima),jer ce prilikom prvog boota zablokirati SE Linux koji inace nema podrsku za resier-potrebno je prvo podici sistem,iskjuciti SE Linux i tek onda se igrati sa resier particijama-tako je,bar ja mislim,najprakticnije..
Александар Урошевић
ГНУ Шумадинац
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 527
Proprietary hater
WWW
« Odgovor #24 poslato: 26 Децембар 2006, 08:34:21 »
Citat: Seleuk
Meninije samo jasan jedan detalj. KDe se vrti na X-u koji je podignut sa nvidia drajverima, vlasničkim. U svakom trenutku mogu da poteram Beryl i da izaberem KWin ili Emerald window menadžer. Sada mi nije jasno, na čemu radi taj Beryl/Emerald ako nije AIGLX?
tomaja
Administrator
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 2728
« Odgovor #25 poslato: 26 Децембар 2006, 08:51:36 »
Dobro, evo sticky Wink
Magnetic fields are always in mine mind
моје приче /home/tomaja
debelizmaj
Sr. Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 339
bla bla bla
« Odgovor #26 poslato: 28 Јануар 2007, 19:22:48 »
Desilo mi se nesto ruzno..taman sam poceo da koristim fedoru kako treba i uzivam sav u njoj kada mi se posle jednog updatea pokvario gnome...naime na donjoj liniji na kojoj je ikonica za trash i 4 desktopa vise nema pokazanih upaljenih programa, ona je samo bela tako da programima koje "spustim" mogu pristupiti samo preko alt+tab nikako da kliknem na njih na donjoj liniji...
kako da popravim ovo
debelizmaj
Sr. Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 339
bla bla bla
« Odgovor #27 poslato: 28 Јануар 2007, 21:18:54 »
nervira me ovo mnogo..smanjuje mi ugodnost pri radu, cesto zaboravim da mi je nesto otvoreno....dajte pomagajte...
moonbeam_rider
Poser destroyer
Hero Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 1559
WWW
« Odgovor #28 poslato: 29 Јануар 2007, 01:53:12 »
Malo zvuci banalano,ali da ne koristis mozda AIGLX-on zna da pravi bas takve stvari uglavnom kada su u pitanju ATI kartice....
Da li znas sta si upgradeovao od paketa?
Ono sto moze da pravi ovaj problem je gtk,cairo ili neka do gnome biblioteka
Jesi probao da uradis upgrade gtk i gnome-panel-a,te gnome-menus-a preko yuma?
debelizmaj
Sr. Member
Van mreže Van mreže
Pol: Muškarac
Poruke: 339
bla bla bla
« Odgovor #29 poslato: 29 Јануар 2007, 11:52:27 »
Updateovao sam preko 250MB...to je bio neki normalni update...pojavila se ikonica gore desno (kako ovo debilno objashnjavam Cheesy) i ja kliknuo i dozvolio m pdate...jeste tada mi je bio ukljuchen AIGLX...hteo sam da vidim kako funkcionise to chudo...
Stranice: 1 [2] 3   Idi gore
  Štampaj
Prebaci se na:
